Supernait3
Hi All,
New here, thanks for your advice.
I know not ideal, but would a Supernait3 drive Focal Kanta No 3 speakers. I’ll upgrade the SN3 at some point, but not yet.
I think it will drive them well, all focal kanta are very easy to drive.
Yes, the Kantas are a great match with the SN 3. I had the very similar SN 2 and with NDX 2 as source it made great music. The Kantas are excellent speakers, though, and will respond well to upgrades in source and amplification.
When the Kantas were released some years ago they were paired with the SN 2 and the NDX 2 at audio shows. Many forum members were very impressed with the musicality of this system, so it is not a mis-match at all.
What is your source?
Many Thanks for the advice.
I use the NDX2, and a Rega Planar 10 turntable for source. It sounds as though the Kanta’s will work great. I have Monitor Audio Silver RS6 speakers at the moment, a leftover from previous system, so these should be a significant upgrade.
That sounds like a lovely system. Enjoy.
Yes! Had the same configuration a while ago and it worked beautifully. Really got me a taste of what hifi can sound like. I had the Kantas before entering the naim world with my trusty old NAD integrated. The switch to SN3 felt pretty significant. Kantas have been happy to play well with the upgrades that inevitably lay beyond.
You’re welcome. The Silver RS 6s are good speakers too - I had them for several years. But they are outclassed by the Kantas, which have a different presentation and are more resolving. Anyway, as others have said, it will be a great system!
SN3 will drive all the way up to Sopra 2s and Kudos 606.
