I don’t have the Tribes but have heard them and they are very good. I run Totem Hawks on a Nova (the replacement of the Uniti) and very much enjoy that matching, so I would expect the Tribes to be fine. Although the room interaction is always a consideration. The Tribes will also take quite a bit more in the Naim range, so you will be future-proofed!
The Hawks are now discontinued, but of you could find a pair, well, they have a certain special character that is very appealing.
SuperUniti handles 4 ohm loads no problem. We bought Sonus Faber Sonetto iii when we had SU.
Obviously a 250DR then 300DR really brought speakers to life, but a SU will have no problems driving that load. You might find clarity falls off at high volume.
Thanks for the info.
I’m also having my eyes on a pair of white Hawks.
But like the Tribe (black this time) they will need to pass the lady taste test. She’s really into the wood speakers… (me too usually)
I guess my strategy should be to show some big black SF Venere 3 first. Then come back with little Tribe or Hawk after as a compromise.
