Yes, it sounds like a faulty logo for sure.
As said above by @nitrous - disabling logo mute in the menu should stop it happening until you can arrange a replacement.
Neil.
Neil.
Thanks Neil. I have the logo set permanently to off…
Thanks Neil, as you surmised, I’d missunderstood. I had:
Logo Off: Always
Logo Mute: Yes
So I’ve changed Logo Mute to No. Hoping that will fix things!
Works for me! I have no real need for front panel mute anyway.
Had the same problem right after purchase. Did change the logo setting and the mute problem was gone.
Many thanks to Neil and others - fixed now
