Superuniti vs uniti
Opinion on superuniti vs uniti
Superuniti is worth the extra, especially now with prices bottoming out.
Just more of everything that’s good about Naim.
I did prefer the Atom to the superuniti - looks, size and performance so subject to plans I would consider that as an option as similar price points.
Gary
Ps be aware that the screens will die on the original uniti products and subject to age may need a service so factor that in to any thinking
The biggest advantage of the Superuniti is the extra power it has to drive demanding speakers and/or produce higher volume sound without it degrading. Other than that I found the difference between the two relatively small.
Bear in mind that these older devices may vary from one unit to the next due to age and service history. Check the serial number and history before you buy.
Before buying my SuperUniti many years ago, I compared it with the Uniti and found it very much better. But the OP gives no background to the question so it’s a bit tricky to know what to say.
I find the Uniti much better at playing CDs and powering my StageLine.
