Sveriges Radio - P4 Norrbotten, internet radio
Friday 17/4.
Problems with P4 on my Naim MuSo 2 on all stations except Stockholm, Blekinge and Västerbotten.
There are 2 Västerbotten, the one without a hyphen after Sveriges Radio (Sveriges Radio P4 Västerbotten) is the one that works.
“Sveriges Radio - P4 Västerbotten” is the one that doesn’t work.
All the others, just over 20, don’t work.
Blekinge and Stockholm have hyphens.
Streaming via Sveriges Radio’s app works, I’m running it via AirPlay to the Naim now.
I got the correct URL:s from Sveriges Radio, an they are working when I create a RadioStation manually.
So you have to update your database.
The correct value for feks “Sveriges Radio - P4 Norrbotten is”:
https (followed by) live1.sr.se/p4nbtn-aac-320 (AAC-LC, 320 kbps)
Here is the link to all correct URL:s for Sveriges Radio:
https (followed by) om.sverigesradio.se/lankar-till-ljudstrommar-for-alla-kanaler
one for @Stevesky
Hi @heggan_lule
thanks for the report. Bit of an unusual one as the streams play in our station scanner + in a browser but not on the products due to a bad redirect.
The url’s are now adjusted and all should be good agsin.
Best
Steve
Working fine now!
Thanks for fast reponse :+1:
