SVS SB2000 Pro subwoofer
Hello, Naim friends,
I was wondering if the SVS SB2000 Pro subwoofer pairs well with the Naim Nova?
I’m using Dali Rubikore 2 speakers.
Hi,
I can give you a somewhat generic answer here. You can certainly try it, but the main challenge will be finding the right crossover frequency and positioning the subwoofer properly.
My Naim CI-Uniti 102 has excellent crossover control capabilities, but with my previous amplifier, I really struggled to integrate a sub properly.
And, of course… moving around a 50 lb box for positioning is a workout in itself.
Best of luck!
Vladislav
I had this sub with Naim Nova and Focal Aria 906 speakers. I see your speakers have a frequency range of 50 Hz – 26,000 Hz (lower roll-off at 44 Hz via the rear port).
The SVS app is good and there are many adjustments you can make to the settings. Agree with positioning comment above - does your room allow it and also is the room itself conducive to “accepting” a sub?
If yes, then, use the very helpful speaker and sub matching tool on the SVS website to see if you’ve selected the right model and it will also then suggest sub settings for you. I did a quick search and SVS recommend the SB3000R and 5000R with your speakers. So the 2000 Pro may not be sufficient to have the impact you need/expect.
The SVS advised Recommended Low Pass Filter Frequency Setting is 60Hz for your speakers.
Thanks for the comments, guys. I’m currently using the Elac SUB 2070, and I’m wondering if I should switch to the SVS SB2000 Pro.
But please bear this in mind.
My opinion is biased… I have 2 of them…
