Having changed houses over the years found the sound I loved then lost it due to new acoustics spent loads of money to replicate it got close but no cigar I had somewhat given up but enjoyed what I had all the same…until now that is it’s easier firing across the room but on the short wall it’s so much harder I found it was either too shouty too much bass or too little bass and my only guide was what I had before. But I tried again inch by inch it can’t be that narrow surely? But just one inch one way or the other till it hits the spot where it comes together is a magical moment. Hearing bass lines all the way through the music mid range subtleties sweet high hats it’s quite amazing and why I started this game! Don’t give up I would say it will come right in the end!
Inch? 5mm more like, and even within that there’s a sweeter spot. Having something that lets you micro adjust the speaker position is invaluable, even if you remove them later.
You may well be right but one inch seems a lot to me given the distance to myself, it sounds great I dare not move it
Do you have to lock your head in one position, and not move an inch?
No it sounds good from the sofa either side if centre
Been there done that with a house move and the “sound collapsing” it was so frustrating……
Gary
It took me a few years but happy now!
Russell K recons once you get it right it sounds better anywhere in the room😁
I agree you don’t have to sit in the middle with your head in a brace lol
