Take two but demo items as prior Synergistic Research power cables did not allow easy plug fuse removal, only the power cable was brand new USB and speaker cables had demo run in.
Prior Setup- rated this as 30% baseline
Naim Nova, Innuos Zenith, Cisco 2960, Focal 1008be2, Naim Fraim
Synergistic Research fuses, speaker Carbon XFT, support Mig 2.0 and Nova power cable.
STEP 1 - Swapped Wireworld Starlight USB for Synergistic Research Atmosphere Reference 60%, more air, details, wider soundstage, backing vocals audible but weak, better PRaT
STEP 2 - Swapped Naim NACA5 for Synergistic Research Foundation speaker cable
Rated 90%, improvements in bass, vocals, soundstage, more air, PRaT faster, more transient details and much wider soundstage.
STEP 3 - Swapped Nova Synergistic Research power cable Atmosphere for Foundation
Rated 100%, more PRaT, backing vocals better, air and separation.
STEP 4 - Swapped MCRU power cable feeding Innuos Zenith with Synergistic Research Foundation
Rated 120% - Bass layering detail, backing vocals clearer, more air, better decay, wider soundstage, midrange more bit and attack and even more transient detail.
Have a two week demo, so far impressed, i would say each step just adds more realism, real toe tapping, emotionally engaging.
I do feel the air, PRaT and transient detail really brings the experience more 3D, versus more baseline, which i would describe as wooley base, bad timing, no air or soundstage.
Will be interesting the see how things settle with more run in, in particular the power cable.
Oh it would be 100% Synergistic Research, but my Ethernet is still Wireworld Platinum and the Cisco router has a stock Naim power lead.
