Synology tips, tricks, hacks, and help
Link aggregation doesn’t double the bandwidth for a single data transfer task. It should handle multiple date transfer tasks faster though and provides link redundancy..
Agreed. I also brought my offsite machine home so was restoring from two machines at the time. My NAS gets hammered by multiple devices.
Yes, probably too advanced for what I need to do. I’m going to try the USB Copy package and see how that works. Will report back over the weekend.
Well, that was quite a long weekend but I finally got to the USB Copy package and tried it out.
TL;DR: way too much faff. I read the instructions, it did my head in, and I resorted to the old drag-and-drop method.
If you’re wondering if you should use it - don’t bother unless you work in IT, you’re a masochist, or you’re looking to waste two days learning about servers / file system organisation.
MF
I use Hyperbackup to back up to a 5 Tb USB SSD which works seamlessly every night and swop it out for another identical one kept off site once a week !
Thanks; this was a specific application where I’m transferring about 400GB from an SSD to the NAS. Trying to consolidate all my backups.
Aha I see, sorry got it round the wrong way
No worries; if I was in the pure backup game, it would be a lot easier!
I’ve tended to use my pc to transfer from/to a usb drive plugged into the NAS - with usb 3.0 I think (blue colour plastic inside usb connectors both NAS and USB drive), both NAS and PC ethernetted to router. Never been a problem for me, and while not super speedy is quick enough for 500gb. A lot lot less than 2 days… And while in some ways Synology DSM is magic, for file transfers other than whole directories I find it a pain. If your NAS only has USB 2 port then that’s probably the limiting factor. USB 3 stick into you computer and off you go?
It can be both satisfying and a teeny tad frustrating to spend 2 days acquiring a skill you use once, that saves you half an hour and your computer 4 hrs run time. Nerds of the world unite (don’t mean to cast aspersions). Could you still listen to your music while it was transferring? The terrible thing at my age is that the skill has a half life of around 9 months.
I have an older Synology DS214play it still works fine but I’ve bought a new DS224 and new drives for it. I guess the simplest way to copy the files is just drag and drop over via Ethernet?
I don’t know if newer Synologys allow drag and drop file transfers over a network, but even if they do I have always found them to be slow. Putting the files on a USB drive and connecting that to the NAS might be quicker.
I believe it may be possible for you simply to move the old drives to the new Synology using drive migration and then you could swap the old drives for the new drives in the new Synology? That should save time overall?
So I moved the NAS to the lounge where the main router resides, as well as the modem. Much more stable than when it was in the office on a secondary access point. That said, transferring anything over 100GB via wifi is just a recipe for failure.
I chopped some folders into manageable pieces and got them across. But the days of large-scale file transfers of that size are over for me.
It’s a shame that NAS makers don’t include the ability to plug and play an SSD drive for file transfer. It really limits the use case for a NAS if you can’t move quantities of data quickly and safely without a degree in Computer Science.
Connect any drive (using a USB to SATA adapter if required) and use Synology USBCopy or just drag drop within DSM file station (via web GUI).
Both methods transfer data directly through the NAS, not over network, using simple tools.
USB/SATA adapters cost peanuts.
They do, in the out of the box config!
Doesn’t work for me - plug in the SSD and the NAS doesn’t recognise it
Well that’s a different issue.
I just plugged a portable Seagate SSD into front USB on our Synology DS220 and in Control Panel/External devices…
I’ve never found our NAS to be very fussy, despite a claimed compatibility list. It has recognised various prepackaged USB SSDs like the Seagate one, various SSD and spinny drives via USB/SATA harness and any number of USB thumb drives.
What drive are you trying to use, and how is it formatted?
Seagate Iron Wolf 4tb
I use Seagate EXOS. Been solid since 2020.
Samsung T7 SSD; ExFAT
I can see the drive in Control Panel, but none of the files / folders show up - just blank. It says there’s 2 partitions (which there aren’t - I didn’t partition the drive) and it wants me to install ExFAT on partition 2. So now I’m super confused.
