I still rip cd’s from the Unitiserve. But listen to them on the Uniticore. After updating the DSM to 7.0
I lost the connection Unitiserve to the NAS(DS418PLAY). Every time I make a new music store I get “cannot authenticate share”. The Uniticore/Naim app is showing the shared folder music. That is great news. But failed on promoting Unitiserve’s Music Store. I did these changes trying to fix it.
Deleted and made a new share empty folder
SMB1 thru 3 enabled
Local Master Browser enabled
restarted everything many times over.
Full week trying to pick up all the pieces on this. Thanks for reading, regards Rick
Hi @analog414 , you have enabled SMB1 on the Synology but I think you also need to enable NTLMv1 authentication for the UnitiServe. Look in Advanced Settings > Others for the “Enable NTLMv1 Authentication” option as described here:
@analog414 Rats, I thought that would fix it. I had a similar problem accessing an SMB share from a device that only supports SMB1 and enabling NTLMv1 fixed it in that case.
@Mike-B I don’t think this is an Asset permissions issue – as I understand it I think Rick is having problems accessing a music store from his UnitiServe, so this is an authentication/permissions/SMB issue between the UnitiServe and DSM7.
Any UnitiServe users out there using DSM7 that might be able to help?
Rick, it might be worth contacting Naim support for assistance with this.
As no-one uses anything but SMB3 these days and SMB1/2 are equally deprecated, if you set the Synology to minimum SMB1 maximum SMB2, it will go for SMB1. But if you set it to minimum SMB1 maximum SMB3, it will default to its preferred setting of SMB3.
