I’m using an ND555 with a NAC552. My only other input is an AV amp.
The ND555 is on input 1 and the AV amp on input 4.
Can someone tell me (or send a screen shot) of the correct settings in the System Automation menu ?
These are my settings for my nd555/552……you of course need a cable from ir out at the nd555, to rc5 on the 552.
What Gazza posted. In addition, you can go to Settings > Input Settings and rename the inputs from “Preamp 1” etc. to what they really are, “CD”, “Streamer”, etc. Makes it easier to configure the correct one for system automation and for later input switching in the app, too
