System in a adjoining room to the speakers
I have just read a thread from July 2019, about locating speakers away from the Fraim. Sometimes in a different room.
Within the next four months I will be adding a NDX 2 and probably a 555PS DR to my current system. This will necessitate a six level Fraim. Ideally, I would prefer 2x3 levels. However, the new house that I’m moving to, may well not accommodate a 2x3 level Fraim.
I am aware that some people put their system in a different room, leaving just the speakers in the listening room. The only issue for me, is that the NARCOM 5 remote is Infrared, and won’t control my NAC 282.
Is putting the Brains/Brawn in a different room a viable option?
I can’t see why not. If you’re adding a NDX2 then you could setup system automation to give you volume control and input switching on the 282 via the app
I’m sure someone with some personal experience on this will be along in a mo. I’m not a big fan of showcasing my audio setup, so this is exactly what I would like to do in the near future when we move. So I’ll be following your thread for any tips on effecting this. I would love to just have all the equipment somewhere else, with just the speakers in my main living area, and control everything with the Naim App.
I suspect that very long speaker cables are the main ingredient.
Cheers, and best of luck.
Thanks David.
Thank you @james_n . It’s been about eight years since I used the Naim app, which was on my old ND5 XS. To be honest, I can’t remember what the app can, and can’t do.
My system is in a different room to the speakers.
I control the NDX2 and 282 via the naim app.
No problems whatsoever
Previously I had a CDX2 and 202 but used an infra red extender. Forgot the make but it was a small pyramid shape. Also worked with no problems.
One advantage is that the system sounds better. I guess this is due to the drastically reduced acoustic “feedback”
The more you de-couple the source from the LSs the better. You may have a bit of walking to do.
Yeah it’s changed quite a bit. There’s quite a step change between the old app I used with my NDX and the new one I use with my NDX2. At least you have a few options depending on how much room is available when you move.
James
IR repeater and that’s it sorted.
I had no idea that could be done, great! :+1:
Thanks James :+1:
There’s no info on the Naim website nor in the manuals, but search for"system automation" on the forum and you will find all you need
Thanks @Suedkiez
