Lovely, Nait 1 for me too (Not that I would sell my Nait2).
thank ya. I am lacking proper bass traps in the corners of my room and those are on my wishlist.
Happy Hanuka too
I have two the front corners and two behind listening position. Subtle but worthwhile improvement. How are the ceiling diffusers?
Hi tricky.
Your stack looks like mine probably will; Iâm in the process of moving from 4 to 6 shelves in that same colour scheme. The concern here is that 6 might look a bit too high or just top heavy, the pic you posted here suggests maybe not - could you perhaps post an image or two that shows your Fraim stack with a wider context of your room decor? Anyone else who has a Fraim 6-pack feel free to do the same.
To bat off the obvious answer, there isnât the floor space to do the 2 x 3 stacks in that part of the room.
Thanks muchly.
Almost the same size I believe?
Adding the NAP 300 has made them sound twice as large, quite phenomenal how much scale and weight can be added without ruining the overall balance. I didnât realise the S20âs were this capable.
I bet 606âs would be something else though! It would be an interesting comparison, 250 DR + 606âs vs 300DR + S20âs, assuming that the same room worked for them both.
Room is everything of course. S20s never worked at all where the 606 sit presently, but all things being equal iâm sure S20/300 vs 606/250 would be interesting!
Sorry, forum rules apply.
The ceiling treatments made a noticeable difference. This room has low ceilings and the huge Focals were reflecting all over the place (especially from ceiling directly above my listening spot), and the Flexiwaves calmed things down. I really noticed a more settled sound in the higher frequencies. Hindsight I couldâve opted for a more cost-effective solution but I am happy with them.
Great pic!
Out of curiosity, whatâs the room youâre in? With the stairs one might wonder whether youâve been banned to the corridor.
Haha yesđNo actually itâs the main living room, which is L shaped. The stairs are a pain in the arse, but itâs the only place for the system such is the layout.
You do need clean records though, it gets deeper into the groove than just about anything else.
Luxman⌠sweet.
Any experience on Accuphase? ( and how you compare)
Gary, didnât you use to have Shahinianâs?
New pair?
Lovely looking setup Tricky. What distance are your speakers apart?
Judging by the photo I assume they are closer together than you would like but I bet still sounds great.
Yes new pair, replaced the Shahinianâs a few weeks back.
Looks like you have optimised the room pretty well. Most rooms are acoustically difficult unless you are very lucky. 272 maybe a keeper?
