Really nice setup. I bet it performs well with all that space around those speaker.
Thank you. The size and the space it affords is good, the windows less so for audio, though itās a great room for living, which is worth something Though the space around the speakers helps with this as well, I think. Overall Iām delighted with the sound, but there is much more potential with some treatment. Just starting to look into ā¦ I see another project on the horizon
Thatās a solid, good-looking remote for sure.
I was very disappointed with the Nova remote having changed from a Qute, which had a very solid remote. This one looks rather better though.
How are you finding the sound quality of the remote? Does it need much run in?
Itās pre owned and therefore a couple of years old, so is fully run in. The thing thatās always disappointed me about the NDX2 is its remote, which is to me not as nice as the previous Uniti remote that went with my SuperUniti and then 272. The new one is just too shiny and plasticky and somehow just not very classy. Itās perfectly functional of course, which is what ultimately matters but youād hope that a Ā£5,000+ streamer would come with something a bit nicer.
Thanks, yes I was referring to the Nova.
I would move the clothes dryer to the left a little.
Lovely looking system and room!
This is much better than the shiny piano black Uniti series remotes. The button lay out looks identical, I wonder if this is compatible with Uniti series as well ?
Hi Graham,
It is possible to use two power amplifiers instead of three, by wiring the bass drivers in parallel?
since Ovator is a two-way design. The two bass drivers in each loudspeaker are fed with the same part of the frequency spectrum. The cost reduction is significant .
Did you try bi amplification in the first place or did you choose tre from the beginning?
I started with two NAP300s, using a Y connector made by Naim so that both bass units could be driven by a single power amp.
Later I demoed using three 300s and there was an audible improvement in SQ, with tighter control over the bass. Hence why I know have three power amps.
I canāt imagine that it wouldnāt work as all the steamers use the same software platform. You may get a surprise if you ask a dealer for a price of a new oneā¦
You still canāt do much with it though. Unlike the NDS, and I assume the N272, which you had previously, it cannot be used to browse your music directory and select an album or track, for instance.
How do you get on with the ATCās, Iām considering getting a pair.
Tim
Same here could you provide some details
