System Pics 2025
I’m also toying with getting both and maybe not getting the P8 to replace my RP6. Put the 1300 on the Naim system and the 1210 on the Technics.
Just then brings the dilemma of dealer loyalty, as my long term dealer doesn’t do Technics.
Small update - back to two Fraim stacks!!
Much prefer the height.
Left
552DR
300HU
Chord DAVE
Innous Pulse
Right
552PS
300HU
Spare
SBL Mk2 with Sean Jacobs PXO
Witchhat Phantom Speaker Cables
AR Lunar RCA to DIN
Right stack, Fraim Lite level makes up the Fraim base, the rest full fat Fraim
Powerlines on the 552DR and 300DR
Hi, the support is a custom made base made by NA. (I bought it used)
My system lost a bit of weight over the holiday with my much loved 52/300dr and wall shelf out and the wonderful Nait 50 in.
That’s a lovely setup, Graeme. Those 606s look right at home there. Did you have SBLs before ?
Thanks @james_n, and yes the 606’s have replaced my SBL MKii’s which are now doing a fine job in my second system.
Nice. What’s the silver box on the second shelf from the bottom?
I just replaced my desktop system’s UnitiQute 2 with a NAIT 50. Wow - it’s quite a special integrated amp.
Before
The Esoteric player was on the left and the dCS Bartok Apex was on the far right .
After
The dCs Rossini Apex takes the place of the Esoteric player
The beautiful curve and line profile of the dCS Rossini Apex.
New member to the NC naim system, and coincidentally , all white lights ! :smile::clap:t2::muscle:t2:
I think it’s quite a special amp too, I’m really enjoying it. The box on the second shelf is the Imperium motor control unit for my MG-1 turntable.
Nothing changed in the past 6months. Hi line due this week to go between Nait 50 and ND5XS2.
Nothing new since last year except replaced hiline and naca5 with super lumina interconnect and speaker cable which was a significant upgrade in every aspect of the musical performance
Despite the current firmware issues my system has never been more enjoyable
No changes here but very happy with SQ.
Oooooh Yeah!:grinning:
Olive is back and successfully.
Rock and roll😉
New deck next to its bro of an amp, sounding very cohesive and propulsive even with the free Project Pick IT silver cart (rebadged Ortofon 2M silver).
Couldn’t resist the draw of a strobe???:wink:
Guilty as charged, bloody great deck.
P8 will have its work cut out for me not to plunge for the 1300 for the Naim system, or indeed another GR2.
I absolutely love mine👍🏻
Sleep on the couch😂
Thanks. Will we be seeing a pic of yours with those DBL’s?
Do i need to reconsider my P8?
You are a bad influence.
