So many possible responses to that, all of them deeply scurrilous.
Mark
Mark
Plenty of ideas, so I’ll put one more on the table. Superuniti is 80w. That would means waste duplication of DAC and I don’t know for Roon integration, but I guess with your actual hardware something can be done.
But for sure sometimes you can get second hand for real cheap. A few weeks ago there was one in west Canada from a dealer with a new screen just for 1600$. That means in USA something close to 1200 $US at max.
That If you are looking for a cheap way out of course.
It’s NextLevel Hi Fi. They do a lot of business with customers who trade up and thus have that used gear to sell off.
Nice, thanks.
So I picked up a super cheap ChiFi amp (Ayima a07) so I can at least listen to some music while I look for the perfect amp deal.
Thanks for all the suggestions. I’m thinking Supernait 3 or get the intro preamp/amp combo instead of the entry integrated. I’ll still try to get used, just better deals to be had.
Skip the 5si is my advice. It’s a good little amp, I have one that I use in a second system but I find it can be a little 2 dimensional. It is really fun to listen to with my bookshelf speakers and It has good dynamics but the sound is kind of stuck at the speakers if you know what I mean. If your speakers aren’t an easy load then I’d say that effect will be even more so.
Cool, thanks. I will try to find a Supernait 2/3 or entry pre/amp
