Tellurium speaker cable
Hi is anyone using tellurium speaker cable was thinking of trying black ultra
I use Tellurium Black II for my Neat Motive SX1s. I demoed it against some other similarly priced cables, and the difference was stark. Black Ultra II, at about six times the price, should be sensational.
You will likely get more responses if you move this thread to Hi Fi Corner.
Yes, Tellurium Q Black II between my Atom and Fyne F500 speakers. No complaints!
Hi, I have been using Tellurium Ultra Black II for several years and am very satisfied with it. At the time, I borrowed a number of speaker cables from the dealer to test (Tellurium Black II, Vovox Sonorus and Vovox Excelsus and some others). I didn’t find any of them completely satisfactory at the time, although the Vovox Excelsus is definitely a high-resolution, fast and detailed cable. However, it shifted the tonal balance too much into the analytical range. Then my dealer offered me the Tellurium Ultra Black II to test. It was a trade-in and therefore still affordable despite the high list price, but nevertheless significantly more expensive than the cables I had tested previously. At home, I was very surprised. With the Ultrablack II, the sound was significantly more open, transparent with higher resolution, but without any sharpness and with powerful, contoured bass. The individual tones sounded better and the system sounded on a whole new level. The difference was so noticeable that my wife came in from the next room and remarked that it now sounded much better. I have kept it to this day.
Basically, however, it makes sense to test speaker cables at home with your existing system and the acoustic conditions on site. Every system is different and there is no one best solution for everyone. But if you have the opportunity to test speaker cables, I would include a higher-quality tellurium cable. For me, the Ultrablack II was one of the best upgrades ever and well worth the money.
Using the Silver 2
Been using Black II for a number of years with Audiovector speakers. When we moved house I needed a longer run and tried a variety of cables, notably a couple of (more expensive) Chord examples. Went and bought some more Black II. I obviously really like it!
