It’s the same but the wired in the wall are sold core and hardwired.
You can’t have solid core twin and earth on a trailing device.
The wiring is the same and not made up from various bits and having another plug and socket in line.
I know it does not affect you Max in Italy, but UK folks need to be careful with the rules on UK ring main ‘spurs’.
Only one single or one double socket is permitted as a spur.
You can’t take another spur off that spur, meaning you cannot have a two socket (single or double) as a spur.
You can reconfigure the ring main circuit to include the additional sockets, but they must be part of the ring, not a spur.
Adding fuses to protect a spur extension is permitted ….. but this is getting into the regs and it not the place
Something I’m unclear about and which you might be able to shed light on either @Skeptikal or @Mike-B , knowing you both have said you have professional backgrounds in electrical work. Assuming one double socket only, if this is wired with two lengths of 10mm2 cable back to the CU, does this count as ring or a 20mm2 radial? Is there any electrical difference (and audible difference) between this arrangement and having the double socket wired with a single length of 20mm2 cable, ie. a 20mm2 radial? Maybe it’s a silly question, but just puzzled. Thanks.
The grid everywhere is getting worse, and will not improve so moving home will not help much.
There are proposals to change the voltage on the grid yet again, to bring us in line with europe (why not persuade them to move to our standard) and this will mean transformers in equipment are moved out of the operating envelope which will have consequences on sound quality (which may be audible to some folk). UK The sub-stations could have been changed to output 220v ac, but too expensive (remember thee conversion of everything from Town Gas to North Sea Gas, and the huge cost and disruption involved - and it was said at the time the supply was so abundant that it would not be worth metering! haha Rather than this conversion expense, the limits of voltage variation were ‘altered’ to ‘make’ the nominal voltage 230v ac. Voltage on the grid varies greatly (within the new more relaxed tolerance) and this is getting harder to manage with solar and battery feeding back into the grid. If for example hifi using 240 volts is run a a voltage 220 volts, the sound changes. Proposed changes will introduce new limits that will have the lower limit 207v ac.
Have a look at eFixx Electrical News utube…
Hi Pete
It’s a radial.
A standard ring final circuit loops from the CU, connects to multiple sockets or points, and returns to the CU using the same cable size to form a continuous loop.
Connecting two identical cables in parallel to feed a single point or load is a parallel radial not a ring.
Even a separate spur to the CU is preferable to ring.
In fact new regs for gas boilers have to becwired independently from the ring now.
Thanks Skeptical. We might think about installing a dedicated supply within the next couple of years, all being well. It’s going to be a big upheaval but perhaps worth it and it’s really the only thing I would now be interested in doing as far as performance goes. Finances need to recover first though, and the C/H boiler is now playing up too! ![]()
Still not happy with the sound then Pete?
Very happy yes, and there’s absolutely no need at all to do anything else. But since when has that been a reason for an audiophile not to do anything else? There’s always that one last fence with the greener grass on the other side of it. Silly - but that’s the way it is. It might well not happen though. Just a thought and not sure we would want to face all the upheaval anyway.
You’re welcome
I’m glad the system is living up to expectations.
We got a new boiler a couple of years ago and I knew it couldn’t be plugged into the ring now so a dedicated line from CU is installed.
I said to Mrs Skep the heating will sound good as the hi fi now.
They do this now so that anything tripping in the ring doesn’t affect the running of the boiler.
It’s in case of anyone infirm perhaps becoming hypothermic in case of a fault and the heating goes down as well. ![]()
Any particular reason why you are considering this? Naim recommend a single 10mm radial circuit for even their larger systems, so I’m not sure you need twice as much copper as that!
Seriously bad attitude pf mind that is as likely to be wrong as right, but mentally you can lead yourself down the path and always believe, believe, believe… Yo have done ig before, and I though you had decided to chuck that all in, keep it simple, be satisfied, be happy. (I’m not making a comment on mains here, but concerned that you show no signs of having changed from the habits I thought you were trying to leave behind. Before long it’ll be interconnects, then cable risers, then mains fuses, then green felt tip pen on the CDs, then….
I was just curious as to whether that particular configuration would be classed as a ring rather than a radial. There does seem to be some debate over which sounds best.
I guess I’m a hopeless case. I did say that a dedicated mains would now be the only thing I would consider further and I meant it. Honest I did.
Radial every time it’s a one stop shop. ![]()
I have the impression you said much the same about the speaker cable, then the rack… is there a branch of HA near you? (Hifiolics Anonamous)
Well what one intends to do and what one actually does may not always be the same. Outlook can change, views become modified etc. etc.
I must say I have been taken aback by the abilities of this system. I’m familiar with Naim, having owned it in the past for many years, so I knew broadly what to expect and of course that was the whole driving force behind the change. At the same time I had a desire to simplify things and we just didn’t have the cash to invest in a more high end Naim system anyway. What I’ve ended up with is of far greater ability than I had envisaged it would be. The CD5si, although Naim entry level, has no obvious weaknesses and far surpasses the Moon/Qutest in terms of musical engagement. That’s no exaggeration. The Nait 50 is clearly something quite special and again has a musical engagement factor that far surpasses our previous Moon amp.
It’s this unexpected ability that caused me to re-think things a little. I now see the Fraim as essential in avoiding any dilution of the system’s important qualities - nothing else would do for me. Ideally I would love to fit a dedicated mains for exactly the same reason. As far as cables go, well I already had the Powerlines. But I have no desire at all to change to a HilIne or Superlumina cables - and I certainly would only ever consider Naim cables, nothing else.
You had no desire to buy a Fraim Pete but here we are. I know it’s ok to change your mind but you are on another level completely.
I’m just the kind of guy that does things like that. ![]()
That is your belief, but only an assumption as, at least according to your reporting here, you have never compared them! For all you actually know you might find it the other way round if you were to try, though you don’t want to and I don’t recommend you do now for more than one reason.
