For absolutely no reason other than ‘because I could’, and with due acknowledgment that it’s childishly silly and utterly pointless, I thought I’d see how many of the LEDs I could get to light up at once on my CDX2.
Using Mike Oldfield’s HCDD remastered Amarok meant I could get the HDCD light on and get the time display on a suitably large value. Pausing it at 58:08 could get every LED apart from three on:
Not quite sure what you mean, but I did have to be quick on the camera because the HDCD light goes off in pause mode (after a short, er, pause) so there’s only a short window where I could capture the pause/remote light going on (the right-hand ‘decimal point’ in the time display) before the HDCD light went out.
@NeilS will probably chime in now with some secret code of button pushes that makes every LED light up for testing purposes…
