Hi all.
I’m a newbie to this forum and just would like to share my findings.
I have a uniti atom and two muso 2’s and have gone through a lot of trials and tribulations to come to grips with getting them work together.
For me everything now works in multiroom mode hdmi, playback from usb hdd and even with my trusty old thorens vinyl player and the thing that made all this happen was a factory reset of the atom, haha. Until now that is, the new update ”keeps” the delay over to when I want to use the hdmi, so it’s not in sync anymore. The only way that I can fix this is to restart the incoming router. Any other suggestions?
Merry christmas to all
Merry Xmas, I’m sure someone will be able to help, but not me afraid!
If I have been using multi-room on my NDX2 and Muso-QB,s then I try to watch TV, the sync is badly out. I have to turn off multi-room before selecting TV audio.
Hopefully this might resolve your issue, if that’s the problem you’re experiencing?
Exactly as Blythe states above for me as well. Had me foxed and worried for a few minutes until I realised 222 was still on multi room with Nova upstairs!
If you are trying to get TV sound simultaneously out of all devices that is is also in sync with the TV I don’t think it can be done.
Hi and thanks for the input, will check this evening and get back with results. It can be that I missed shutting all multirooms off. Hdmi simultaneously on all three works for me.
Cheers.
Hi again. Yeah it seems to my own fault. For the moment it works when i close all multirooms.
Thanks for all your help
Ah good. Thanks for letting us know. it is a bit irritating but at least you know what to do now.
