The Naim New Classic range - Part 1
:slight_smile: …I love live music and how it can changes everything. 110dB takes over the body and mind, releasing dopamine and endorphins.
…and thank you for your kind words
Best
Steve
I think Naim do an amazing job considering the quality of the mains supply in Salisbury.
This is possible also with the ND5 XS 2.
I currently use this function and it works fine.
M.
Yes, there is an option in the setup although I didn’t select it.
I really like the look of the new range, probably sounds great too, have not yet been to see Peter to have a listen. I was just disappointed that I can’t integrate any of it into my existing system, fingers crossed naim will release something I can add in the future.
Bit like fainting goats? :smile:
Thanks :pray:
Thanks Jurgen. Steve (@Stevesky) and Steve (@110dB) have made it much easier for me than it might have been if I had had to try to answer all the questions on my own, so I’m very thankful to both of them.
As for the forum, it’s open 24 hours a day, 365 days a year, so there’s no rest - not even on Christmas day!
Best, Richard
On to the next release then :slight_smile:
I’d just like to see the NSC model based more on the NDX2 than the ND5 XS 2. Maybe the NSC 3xx will come…
Thanks for this Steve. Do you have all your outlets running on the same dedicated circuit or do they each their own? Do you do anything different with the grounding in your system (ie isolated ground or running to a separate earthing rod)?
It’s so great to have these answers coming straight from Naim!
The green looks fantastic - warm and classy. The white looks cheap and cold.
Maybe we should start a petition…
I like both white and green, but having the choice to switch between colours via a setting on the remote / app as system components change would have been perfect.
White is the new green ! After almost 20 years of green lights in my living room, it is time to switch to white…blue would have been also nice :slightly_smiling_face:
Blimey - just noticed, there’ve been over two thousand posts since the 4th Jan! Something tells me there are going to be a lot of new 250s and NSC 222s on order soon!
Seems the new classic range products are stock at the Canadian distributor. Going to my dealer soon to discuss with them. Honestly, i would like to keep my NDX BT which is great and i am not a big fan of screens so i would just change my Supernait 2 for new 200 serie NAC and NAP. I will probably wait for new announcements from Naim.
I don’t like all my eggs in one basket. I like a shoebox that is just an amp.
NDX2 costs more than the NSC 222 and yet the NSC 222 needs to contain a preamp as well as streamer DAC. If NSC 222 had been based on NDX2 there would have been howls of protest at the price it would have come in at
Yes, but…white display as current NDX2 and the rest in green. I consider it a must have :slight_smile:
No and I should. Roy George and Paul Stephenson have separate earth rods IIRC.
I have multiple MK sockets being fed from a separate switch and spur from the consumer unit…I’m a beginner :wink:
