Good people - I discovered (!) today that Im powering my NAC 252 with an Olive SuperCap.
This works fine. It seems.
But - information on different forums indicate that I may be mistaken and that you should not use a Olive SuperCap for the 252.
Will something brake? - or will the sound be better if I switch to a SuperCap 2?
No problem using an Olive Supercap on a NAC252. Nothing will break and it will work very nicely. It may sound slightly better with a later Classic Supercap but most things remained the same so any improvement will be marginal. Of course the current Supercap DR would likely give you a nice upgrade over either.
I bought the olive SuperCap to power my Prefix and I recall having it serviced by Naim.
Not sure.
Can Naim tell me the service history based on the seral number?
