When using the Tidal app (rather than through Naim app, which has no problems but the interface is terrible) my Atom doesn’t show up in any connect options including Airplay and Chromecast. However, I have a Sonos soundbar in the next room that shows up. When I move out of range of the Sonos, the Atom suddenly appears (it is connected by ethernet, whereas the Sonos is wifi connected).
Also, FYI, I didn’t experience this issue with Spotify - all devices appear. Any ideas? The Sonos appears to be “blocking” the Atom. I could put them on two separate networks but I’d prefer not to. Using Bluetooth to connect the Atom is also an option I suppose.
I have another question, why is tidal not showing on the atom home screen? Spotify is displayed (which I don’t use) even though it has been disabled from connections … How come?
Have you enabled Tidal in input settings? In the home screen, tap the gear wheel, then Input settings, then Tidal and make sure Input enabled is ticked. It should then show up on the home screen.
Web streaming services cannot be controlled via the remote control/front screen, so are not displayed. (Don’t ask me why?!)
Spotify is shown because it takes you to the Spotify app, as the Connect thing controls the streamer from there. Perhaps when Tidal Connect arrives that will also appear of the screen.
