Yes, all seems OK now.
Better than OK.
Since the Tidal software pre update reversion install, I’m noticing more space around instruments and definitely a punchier bass.
Hi, I also noticed audio definition improvement, and audio quality is now showing in the app under Track playing (FLAC, 44,1Khz) which was not the case before.
Great to have this information !
I’ll have a listen shortly. Tidal does sound somewhat flat and uninvolving mostly.
Have you tried logging out and in… have you checked your subscription hasn’t run out?
