Since latest SW rev my Mu-so Qb2nd generation loses Naim app connection, as soon as I use Tidal connect. It happens than within the next hours.
Even while the app does not show anymore the Mu-so, I can use Tidal connect out of the Tidal app or use it with Bubble upnp
If I don’t use Tdal connect, instead Tidal out of the app, the app runs very stable…
Glad it’s not just me! This started happening to me as well. It feels like it’s more recent than 4.3.0 release - maybe I am just using Tidal Connect more, but I had to re-start (plug/unplug) my Qb2 pretty much once a day in the past few days.
Yes, pulling the power cable helps for me also…but pretty sure, that I don’t want this as permanent solution So I don’t use Connect anymore, even I prefer the Tidal app.
