Tidal connect lock up
Hi all,
I’ve experienced my NAC 222 freezing after 3 / 4 tracks when using tidal connect as the source. Resulting in an un-plug reset. Anyone else having this issue? I’m
I have seen something similar on nd555. If this happens with frequency for you an idea could be to get into the beta program and send logs to naim. These connect issues seem to happen for no gknwon reason currently so hard to cure.
Claus
