Tidal connection
Hi and merry Christmas to all Naim members, as a new member I would like some help, I have recently downloaded tidal on free trial and for some reason I cannot get it to connect to my system, can anyone help please, thanks Marc.
To all I know, the NAC272 does not support Tidal Connect.
I think you can use Tidal inside the Naim app with that generation of streamers.
Yes 272 supports Tidal (up to 44/16) found within the Naim focal app. You will need your tidal login details.
The 272 must also be updated to thx latest firmware version or you will not be able to login to tidal within the Naim app, requires firmware 4.8
Thanks to all who replied, I’ve since found out that I’m only running firmware 4.3 hence no Tidal, how do I update to 4.3? Can I do this myself? Thanks Marc.
