Hi all since purchasing my naim streamer I have really enjoyed the quality of Tidal.
I’m Thinking of moving over to Tidal family but it’s not exactly clear on price and how you link family members.
Spotify is one set price,but I’m not sure if Tidal is the same.
If anyone is using Tidal family and could answer these questions it would be much appreciated.
In Canada its $30 a month. You can have up to 5 accounts. You log in to your main Tidal account on a web browser to create each new log in. They will then have their own favorites, suggestions etc which won’t show up in the other accounts.
Tidal Family is +50% of your current subscription… in Switzerland Hi-Fi Subscription is CHF 25.90 so the Family subscription would then be CHF 39.00.
As far as I know you can add up to 5 family members.
Hope that helps.
Thanks for the reply’s. I just wasn’t sure if it 50% off each family member you add.
Which would make it quite expensive!!
Adding up to 5 people for a set £30 seems very reasonable.
