good evening, it was really easy. you just need the correct cable. i use mac so needed a usb c to usb cable.
get the software from the Naim site here…
in my case scrolled down to streamers, second section, downloaded it, mounted it (as per mac) and just followed the instructions. i did have an issue the first time around but had a chat with Ross at naim, third time the update worked.
so far Tidal seems way more stable aswel so worth looking at
