Hello everyone,
Is a Master-level file from Tidal kept the same quality when I play it using the Naim app in my streamers?
In the current state I do not have any information about the file, which is played in ND5XS2
Naim streamers do not currently support MQA, so if you select a Tidal MQA album, it will automatically play a regular 16/44 version. That’s why the Naim app does not identify MQA files as such.
If you use the Tidal app and cast to the streamer, you can have the ‘first unfold’ done by the Tidal app, and strewamed to via Chromecast if you prefer it.
