Tidal Playlist problem
Good evening everyone. I have a question about Tidal. How can I sort the Tidal playlists in the Naim app by recently added? I didn’t find a way, especially since the playlist on my iPhone is sorted like this. It’s annoying to scroll to the bottom of the playlist every time to hear the latest tracks. Thank you…
On the Naim app home page, go to playlists, scroll to the bottom of the list and select More.
Then in the top R of the screen you should see A-Z. Tap on this, and there will be various options, including a choice between Date Added and alphabetical by Title.
Thank you ChrisSu,
However, with your tip I can sort the playlist itself by date, but not the included titles. Or I’m doing something wrong😔
If you mean the order of the individual tracks within the playlist, I don’t think you can change this in the Naim app. Having switched to Qobuz a while back, I don’t currently have an active Tidal subscription, but you can change the sort order in the Tidal app. Whether the Naim app would pick up these changes I’m not sure, but you could use Tidal Connect to play the re-ordered playlists on your Naim streamer.
