My naim unity nova was having issues playing Tidal from the app. I started streaming from the tidal app and it would work. Then it started having issues from the app too so I downloaded Qobuz and it worked fine. Eventually neither would stream from the naim app. Then the update came and I expected it to work better. I’m still having issues streaming both apps inside the naim app. Only way it works is streaming from the tidal and Qobuz app.
