Tidal recommends playlists for me, how do I copy them to the Naim app please?
I have a non Bluetooth version NDX.
Unfortunately these cannot be seen in the Naim app. If you go to the Tidal app and save it as a regular playlist, you will be able to see that and play it in the Naim app.
Thank you Chris that works a treat!
It’s not ideal having to use workarounds like this, and I did ask Naim a while ago if they could do anything about it. You can’t see them in Roon either, so I suspect it’s something Tidal would need to change at their end.
Is the problem the same on the newer streaming platform?
Yes, it’s the same.
