I’ve found that if I want to search for music in the Tidal app, I can’t seem to find a connect to (my naim player) button like there is in the Spotify app.
Is it just me being blind or there isn’t functionality to directly connect to the muso/naimuniti from the Tidal app itself?
The Spotify Connect feature is what connects their app to your streamer. Tidal does not have this, although it will be introducing it soon. Until then, you have to use the Tidal input in the Naim app.
