I have a first gen Muso and I typical use Tidal via the Naim app.
As of yesterday Tidal has stopped streaming. That is, from within the Naim app, I can select Tidal, select an album or playlist etc. Tidal shows the selection and tracks that are being loaded but nothing flows to the Muso.
The standalone Tidal app functions as expected on my Android phone.
Everything else in the Naim app appears to be functioning i.e. Spotify, Bluetooth, iRadio, presets etc.
So just Tidal.
Has anyone else experienced this ? Or anyone who can suggest a fix ?
Powered down my router, then it wouldn’t talk to my WiFi mesh. Restarted my mesh, but it wouldn’t come good. Had to do a factory reset of the mesh devices which in turn triggered a software update.
So eventually got everything back to where I thought I was.
Hi Richard. We have seem some outlier issues where products are affected by multiple users of TIDAL on the same system - is this the case in your household?
The good news is that @tomvamos and the App team are on the case, and that a workaround (choose iRadio then back to TIDAL) should the issue occur is available in the meantime.
