Is anyone else having problems listening to Tidal via a Unitiqute 2? The music keeps stopping and then carrying on from where it stopped multiple times.
Yup via NSS 333 & Uniti Star. Doesnāt play, stops suddenly or just buffers via both Naim and Tidal apps. Tried logging off and on, force stopping and restarting the apps - all to no avail. Gave up and rejoined Qobuz which works fine - as does Internet Radio and NAS streaming so not a network issue.
This sounds like what Iām experiencing
@Richard.Dane @NeilS is there any problems with the new software?
Intriguing post - since when has a UQ2 been able to stream Quboz?
Try a factory reset, after restarting your router / modem. Doles the issue persist?
Not that I am aware of.
Neil.
Iāve got the same problem. Downdetector (in SpeedTest) says there are āPossible Problems at Tidalā. Looks like itās at their end so nothing we can do at the moment.
Iām not using one - see first sentence of my post.
Just googled it and it looks like Tidals the problem their end.
Sits back and relaxesš
Tidal working okay on Wiim, LMS & Android appā¦
Same on Mu SO and NAC 172 since 1100 today. Down detector shows outages
Was having problems via Tidal Connect in AM. Switched to AirPlay and that was stable all PM!
No idea why if the issue was at Tidalās end.
Tidal okay on muso qb2 & firetv app
Tidal started to stop/start on Lyngdorf amplifier yesterday evening and has continued to misbehave throughout the afternoon today. Though it has worked fine on my iPad throughout.
Hi, same here: stop/start from Tidal on my Nova since today (Brussels, Belgium). Tidal problem or quick drop/restart of the internet? Any suggestions? Thank you.
I appreciate you are not, the op had mentioned a UQ2 and Tidal, so any mention of Qobuz in relation to the opās issue seemed confusing.
All seems to be back ok now. Air play and Tidal connect. Anyone know what the problem was?
Everything solved now. External internet drops were the cause. Sometimes sit and wait is the best strategy (not my best skillā¦).
Im having issues with Tidal connect from my MacBook Pro. It isnāt listed an option for sound output on my Mac but all is good from my iPhone. Ive tried deleting the app from my Mac and re installing but I still have the issue, not sure when this started TBH as I normally use my iPhone for Tidal playback. Maybe it was the most recent Mac OS upgrade to 15.3.1 ?
