Have been thinking of trying Chord or Nordost XLR cables between my NSC 222 and new classic 250 amp. Just experimenting for now seeing if an improvement can be made or not. Any one else experimented with this? Is there anything I should be aware of are standard XLR connectors fine?
I’m sure the standard ones are more than fine the equipment is R&D with what they supply so anything else is just trend and flavours.
Yep I know, but as with all things hi-fi it can pay to experiment and have had good success in the past. Even Naim themselves offer “higher end” cables.
I don’t think you get that much of a change with the high level pre to power IC …. compared to the changes found in the signal level source to pre IC’s.
I believe a lot of peeps were shocked to find a factory supplied XLR looked much like a mains power cable, but nothing much, and a lot more bucks, was any better.
But if you have an itch, and you must scratch it, think about demo sale or return.
Or if you have the skill and equipment, DIY.
Made by them, for their kit.
If you search you’ll discover multiple opinions and experiences around the question you have asked. Some have had good results, on my reading some others are never satisfied, and a fair few return to OEM stuff and conclude it is the best value. It all seems to me that if you are not careful you can spend a lot of money on cables etc when maybe you’d be better saving for more important items such as an NPX power supply for the 222, equipment supports, speakers etc. Maybe you can complete your profile with these? Are you using NACA5? If not that would be a priority for me in most setups.
Homer trial with a return option is the way to go if you must.
Bruce
Yep already have the 300 power supply on the 222, using chord xl speaker cables tried the naim speaker cables and didnt get on with them, I preferred Kimber 8 TC to the chords but could find a pair at the time at the right length. I also have a HRX rack that everything sits on and only keep things that make genuine improvements rather than just sound balance tweaks, other than cables next step would be a 500 amp but thats quite a bit more expensive.
Kimber speaker cables are a big NO-NO on Naim power amps, very high capacitance can push the power amp output stage into capacitive reactance and possible damage.
I believe this is no longer the case since a good few years or even decades with naim power amps
Why do people ask a question then argue with the replies. ![]()
We all hear differently suck it and see. ![]()
Because you are replying with a suggestions that a company makes something in a certain way and it cant be bettered or adjusted in any way I already know is not always correct, it may be the case from time to time yes, but even the company itself updates its components over time. It was like people arguing back in the day you should not tweak an LP12’s its designed to sound a certain way, and now Linn makes LP12’s with the tweaks people were doing already.
There is no reply to your question all you will get is everyone else’s opinion the only way to know for sure spending your own hard earned is to listen for yourself.
The topic can’t go any other way.
Get more confused with opinions or listen for yourself it’s your ears nobody else’s
I feel that there is a lot of hyperbole around the descriptions of effects, with cables in the realm of fine tuning rather than major upgrade. Also, importantly, any effect will depend on the specific items a cable is connecting, and then there is personal taste, so what one person may prefer another may not, so very much a try and see scenario. Personally this is something I can’t be bothered with if the sound is right for me to start with - and if it isn’t I’d be looking at the main components and/or the room. Talking of which, have you optimised your room, speaker and listening positions, acoustic treatment to reduce early reflections, etc? If not you likely would find far greater potential improvement there than cables.
Maybe complete your profile with your entire system etc? It makes it easier for people to make suggestions etc. Budget for any changes helps too.
Have you also searched ‘cables for new classic’ or similar? Lots to read.
Bruce
Don’t fall for justification and expectation bias and try to blind test if possible. The mind can play tricks on you ![]()
Your NAP250 with its regulated power design is one of the classic Naim power-amps where the correct output stage loading IS so important.
Its specifically the latest version
I am getting great results with Nordost power cables and interconnects.
I am using 2 x Tyr 2 power cables in my system and Frey 2 interconnects on Marantz SA10.
I don’t see any reason why you should not try Nordost XLRs.
Why not? Perfectly reasonable to try. See if a dealer can let you demo them or buy used and sell on if you don’t get on with them.
Which Nordost range are you looking it. Also there is a long running Nordost thread on the forum which will be of interest!
Cables can change a system in a very positive way!
BD
Which Chord Interconnects are you currently using?
3 Years ago, I went from an Epic to a Signature XLR between my Streamer/DAC/Pre-Amp and my Power Amp and there was a very good improvement in sound quality to my ears, with more detail being heard, improved mid’s and high’s and better sounding bass.
6 months ago, I upgraded the Signature XLR to a Sarum T XLR and there was an improvement in sound quality but more subtle, this time, again a bit more detail and clarity across the frequency range, but the biggest change was that the sound presentation was now more smoother, a little warmer, more analogue sounding, which to my ears was more preferable, but it was just a subtle improvement.
I have had many different Chord range Interconnects and Speaker Cables, over the last 12 years, but I think the best for sound quality and price is the Signature range, much better sounding than the Epic’s and Shawline’s and not too far behind the Sarum T’s, which are very expensive in comparison to Signature’s.
I’ve just bought a second hand, 20 month old, pair of 3m Sarum T Speaker cables to upgrade from my 10 year old Signature Reference Speaker Cables in my Main System, I will be installing them over the weekend. The Signature Reference’s will replace my Epic’s in my Second System.
It will be interesting to see what sound quality differences there will be, upgrading both sets of speaker cables and systems.
Much better to spend your spare cash on some great music, you have not heard before.
What improvements on your present setup are you looking for?
I can do both so no problem there. Anything that increases the feel of there being real musicians and instruments in the room is fine by me.
