I have an Atom connected to a pair of KEF IQ 90’s, and I am thinking on an upgrade.
- Connect the Atom to an 2006 NAP 200, cost 850 euro, plus cable 160 euro, or
- Buy other speakers
What do you think is the way to go ?
Piet
Piet
We need more information… What are your plans, longer term…? Where do you want to get to…? Have you got a ‘map’…?
Its a lot easier if you have a plan… Any plan.
Plan is to improve the soundstage a little, but I realize this plan is vague. As the wife is concerned no extra boxes, so the Nap is only an option as a replacement of the bluray player which I nearly ever use anymore, or if changing the speakers is a better alternative, but they are standing close to the wall, as I haven’t enough room to move them in front of! I haven’t the option to try the NAP combo but will have a listen with the Atom and other speakers!
I’d be looking at the Nova I think.
Is there anyone with the combo Atom and Tannoy Eaton ?
I’ve just added a nap 200 to my Atom and I find the difference quite substantial. Particularly in the mid/treble. Much more mature sounding and smoother. Also it has given a fuller sound at low volume improving evening and night time listening. I would really only recommend if you plan to remove the Atom at some point and improve the streamer/pre. The money can be more appropriately spent to achieve a two box system. For example, xs2/3 and nd5xs2 in place of the atom. I think that would be a better improvement and less in value than a Nap/ Atom.
Is it me or is this response meant for another thread? I can’t see where anyone mentioned a tab 10.
However, I will add that there is no reason the tab 10 will not be driven by an atom. Sure it will sound better with a supernait 3 and an NDX2 but it is almost 4 x the cost. The tab 10 is a 10 ohm speaker with recommended 5-50 watts.
It seems HH replied to a post by billywindsock that was later deleted
I see.
I have Tab 10s with my Atom it has no problem with them. Brilliant combo.
But at 3k+ it’s not always an option and this is a stepping stone to bigger things. I would love to upgrade to Nova but it’s too steep a jump I could not justify it. Adding on a better power amp I could when they can be picked up for under a grand.
