Yet another tedious Supercap question. I am about to possibly pull the trigger on a s/h 2012 Naim serviced SC which would replace a DR Hicap on my NAC 282 and a non DR Hicap on my Superline. I would then power the Superline via the 282.
As it’s not possible to home demo the Supercap before purchase I would be interested in any thoughts/ advice on the possible pros & cons of this move.
Depends on speakers where best to use the supercap and I’ve never owned Ovators but don’t rule out dedicating it to the superline if you can get a Superline/Snaxo Burndy. Don’t bother using a Snaic except from AUX2, the magic only happens with the Burndy.
For some reason I found a supercap likes the bottom Fraim shelf of the brawn stack.
Yes you can connect the 282 to the SC and the SL to the 282 but I’m not 100% sure where the SL gets the power from in this scenario. With the 252, it comes from dedicated windings on the SC, but not sure with the 282
An auxiliary question to the above. I would be very grateful for any advice/ experience on the merit’s of placing the Supercap on either the 282 or the superline as I have not got a spare fraim shelf for a Hicap & Supercap
Sorry guys misunderstanding I was not asking about placement on the fraim… but the merits of which unit would give me the best results connected to the Supercap or Stageline .
You will get the most benefit using the Supercap on the Superline with the Burndy. The 282 would only use 4 rails of the Supercap connected by 2 SNAIC’s.
The only issue (assuming you are keeping both HiCaps) is if you are using 2 HiCaps on the 282 they should both be the same spec (DR or non DR).
Having said all that, nothing beats your own ears, so have a play around and try some options.
The 282 needs a power supply, unless you have a nap200.
You can’t use a Supercap to power a Superline and the 282 simultaneously.
So you will need either to:
1 Supercap powers 282, Superline gets power from aux2
Or
2 Supercap powers Superline, keep one or both hicaps to power the 282
If you aren’t intending to keep the HiCaps then your only option is Supercap on the 282 and use the Aux 2 to connect the SL. I suspect this could be worse than your current setup, at least for vinyl replay. Would you consider swapping the 282 and 2x HiCaps for a 252? That way you would get the benefit of more rails for the pre and dedicated rails to the SL.
