I’ve just set up my system after several months of downtime while building a new music room. I’m now in the fine tuning stage and need to look at the speakers. Does anyone have the torque settings @Darkebear
Thanks Pete
Thanks Pete
These are a couple of links to places this was discussed a while back that gives the settings and process:
The main thing is to get the PDF from Naim with the torques to verify - I think these are correct but best to also get a copy…of which I seem to have lost mine!
Get the correct torque wrench and away you go!
DB.
Thank you DB I’ll post some pics of the new room soon.
Pete
Interesting … I sent a message to NAIM support to ask if they could email the torque spec document to me, but due to the age of my speakers and the merger with Focal, they no longer have technical specifications that they can send over.
Are the torque settings of the 600s the same as 800s?
Thanks Pete
That’s very disappointing and not at all like “the old Naim”.
I wonder who on earth is making these decisions…
I really wouldn’t want to assume that…
I think @Richard.Dane may have a copy that can be emailed to you🤞🏽
I have messaged you.
That can’t be true, of course they would have the specs.
Martin
Indeed. That’s what I and the OP would have thought!
But it looks like Richard has come to his (and Naim’s) rescue…
