Since a few weeks I’m the proud owner of Naim units Nova on a set of bowers and Wilkins 702 s2 speakers, but when I use my tv as source for sound/music there is a distinct hissing sound, like the voices are sounding a bit robot like in the higher spectrum. And i can’t get rid of it. I’ve tried a connection via HDMI (arc) and optical
Have you set the tv to pcm out?
Have you tried a hard re-boot (power off, remove lead, make tea, replace lead, power on)? Or else a reset of the Nova?
tried a reboot, pulled the power and set tv to pcm
OK, good. Try a reset.
what do you mean with a reset and how do I do that?
