I was sitting in my kitchen working, and literally, all of a sudden one of my speakers began to emanate rather loud, static/rumbling noises, violent enough that the speaker driver was moving vigorously in and out - not a noise you want to hear coming from your speaker, lest a new driver gets added to the repair bill.
I ran over and shut off the 250. Waited a minute or two, then turned it on - noise started, but less than before. Turned it off, and switched the speaker wires. The noise was still less, but was still there, and was coming from the other speaker. Turned it off again, returned the wires to their original placement.
My assumption is that it is the 250-DR - but without another amp, I cannot fully rule out the 272, although it “seems” the 250 would be the culprit. My serial numbers put them at 2015 year of manufacture, but I purchased them second hand. I am also a “leave them on all the time” person (except, of course, when leaving for extended periods or when thunderstorms are in the area.).
Any other ideas on what I could do to nail down where the problem is? I have it on again right now, and the noise is a light static coming from the original problem speaker that I have to get pretty close to hear, but the other speaker is dead quiet. Clearly, something has s**t the bed, but for both cost and downtime considerations, I want to be sure to address the correct piece of gear, as I anticipate a pretty hefty repair bill as well as it taking a month or 2 to turn it around.
Only I could end up with a piece of one of Naim’s most iconic units and have it crap out in 5 years…when 10 or more is a reasonable expectation.
UPDATE: now it is as quiet as the other speaker…but somehow I don’t think this is going to be a “spontaneous remission”. And now I would definitely not leave it on when I am not at home for fear of it going off again and ruining the speaker.
