Turntable placement
Hi, I have just purchased a Muso 2, and want to connect a turntable, the Rega 1+, I have purchased a tv/ hifi unit, I have a tv on it to the right, the Muso in the middle, which is also virtually in the middle of the room, will the T/table be ok on this, and at what distance because if there is any vibration? Cheers, B.
Should be fine. I doubt you’ll get any significant feedback from the speakers in the Muso.
Putting a speaker on the same shelf is going to transfer a lot of vibrations to the turntable. Putting the TT on a wall mounted shelf above is a common way to separate it.
