Turntable Speed Apps
Has anyone used one of the mobile phone turntable Speed Apps. If so how accurate are they.
Noticed some slowwwwdowwwn smearing on my Michelle Gyro SE, tried the RPM app it showed speed variability and high wow & flutter readings. Checked the belt and sure enough it was frayed - actually snapped when I removed it.
With the new belt fitted according to the app the turntable is all over the place and actually slower.
Thx in advance.
One thing to watch with the Gyro and Gyro SE is that there is pretty good height alignment between the platter and the motor pulley. A slight misalignment means the motor pulley can “shave” the edges of the belt and shorten its life.
App-wise, I’ve used an RPM calculator. Of course, the biggest PITA is twiddling that tiny screw in the power supply.
Thanks Roberto - good advice. I’ve been tinkering with the fiddly screw on the power unit.
I keep meaning to compare the internals of my HR PSU with the one that comes with the TT. I am not convinced there is much, if any, difference. Fortunately, I bought mine used a few years ago, but I would hate to pay £800 and find out the internals were the same.
I used RPM as well for setting up my Naimed LP12 with great success.
That would be disappointing - I still have mine so might just swap it back in and see the effect. £800 now, sure mine was a £500 lockdown purchase.
The bundled psu hass the same pot to twiddle to change speed. But it requires the psu to be opened so is even more difficult than the HR version to access
I don’t trust any of the speed apps. They don’t better a proper speed strobe kit. I use the SpeedStrobe from KAB Electro Acoustics for $110. It has the additional advantage that you can put a record under the strobe disc, cue your tonearm and account for stylus drag when measuring and setting speed.
That’s what I use when I change belts on my Clearaudio Master Innovation.
I jave tried “strobily” too. Obviously you need one of this disks with marks on it.
Another vote for the RPM app here. Used it on my Orbe SE and it showed what I thought was a pretty small difference from the 33.33 desired value. After a bit of fiddling with the adjustment screw I got it spot on and it was a significant improvement.
Right, so I’ve opened up the original and HR psu, and they are different. See pictures.
Looks like the HR uses the “ never connected” technology and jas an oversized transformer.
Well that does look much more robust and a lot better designed.
