Tweeters for my IBLs
Hi,
I’ve found a pair of new ScanSpeak D2008 852100s online, at a decent price. Are they ok for replacing the old ones? It’s the type with three holes whilst the new ones have four.
Thanks for your help,
M
Max, the original tweeters for the IBL are the Scanspeak D2008 851100 (three mount holes). The current “replacement” for this tweeter offered by Scanspeak is the D2008 852100 (four mount holes).
Neither should be confused with the old D2008 851200 (three mount holes), which used ferrofluid and is not suitable for Naim speakers.
Hi Richard,
Thanks. All is working ok so far, so here’s to my tweeters’ longevity!
Max
