Ultra - Bluetooth output (tx)
Any comments on Bluetooth out performance.? ANY JITTERS or dropouts?
Drop out, not much, and I even often find the range impressive for what it is.
But sound wise I’m really not a big fan, unless I go with my 2 small Soundlink Bose Micro or Ultimate Ear portable speakers. But then my expectations are set accordingly so it’s doing a ok job.
Not sure if that answer your question?
Bluetooth is more about convenience rather than hifi… it is effectively lossy … … so if max quality is wanted best leave Bluetooth alone.
Max quality is pointless given how knackered my hearing is these days. My preferred endpoint now is a pair of JVC earclips! At least I save a bundle on fancy speakers :blush::notes::loud_sound:
My priorities are source functionality, eg. LMS compatible, Bluetooth receive & transmit, ease of use. The Ultra is probably overkill at the current price, but it does look cool :sunglasses:
Fair enough… I find Bluetooth fine when travelling on the train…
For about half the price you can get the Wiim Pro, which also has two-way Bluetooth. Are there any features on the Ultra that you need?
I like the silver grey version! Matches better than black.
