BenCH
February 20, 2022, 8:37am
#1
hello all Naimers,
does anyone know or a Airplay dongle connected on the USB port of my Uniti 1 will work ?
i use now a old Apple TV connected, but the newer Apple TV don’t have a digital audio out anymore.
i would like to keep using my Qubuz,
thanks for your answers
Hi, you can stream qobuz to a uniti by using bubbleupnp; which feeds services such as qobuz via the network.
I am running Minimserver 2 with the Naim app on my control point very happily with my Synology DS716 DSM 6. rendering primarily to a Naim NAC-N172XS, but also a first generation Mu-So. The server and renderer are connected on a wired ethernet. I transcode from Flac to Wav and all is well, playing up to 192.24.
Separately I had a rest from my Spotify subscription and looked at alternatives and decided on Qobuz. In order to stream Qobuz to my Naim 172 streamer I installed BubbleUPnP server on the…
You could use a chromecast audio which has optical digital out but it is not usb.
ChrisSU
February 20, 2022, 10:59am
#4
The only thing that will work into the USB port is an iOS device, so you could use that but you will need a wired connection.
An Airport Express connected with an optical cable is a tried and tested way to use AirPlay.
BubbleUPnP server as Robert mentions is a good alternative, probably the best option for sound quality.
If you use the old Apple TV now, why not just keep it?
system
closed
April 21, 2022, 11:01am
#6
