A little help needed. I quite often listen to Spotify via my uniti 2 connected wirelessly to my iPhone but sometimes it just randomly disconnects and on ocaasion it won’t show up in the available devices menu on the phone. Very frustrating. Can this be remedied by an ethernet cable from my router…? I haven’t updated it to the latest software but doubt that is the issue…
The WiFi on the legacy products is renowned for not working all that well, even when the product is close to the router. Ethernet cable is so cheap that buying one from any one of a large number of suppliers on eBay for example and giving it a try is certainly worth doing. Cat5e is fine. You don’t want anything fancy as you are just checking that it works.
Best
Thank you, I shall order one today
