Hi,
Hi, I ask for the following information … Help,
With the Uniti Atom, the Spotify app / menu item is on the home screen.
I don’t use Spotify, just Tital and Qobuz. How do I get this Spotify off the home screen …?
Thank you so much
Hi,
Thank you so much
Hi, you can only do this for the Naim app by disabling the input. You can’t do this for the Atom display.
many thanks for the quick response.
It’s a shame why bloatware is pre-installed on such an expensive, noble device …
It’s a licensing thing, no way around it if you want to support Spotify.
It’s a link, not bloatware.
Some people buying at this level will expect it to work instantly with Spotify as that’s all they have experienced. Just ignore it.
(Anyway I guess you can turn it off in setup so it vanishes?)
Best
Unfortunately not
