Can someone tell me how to do a factory reset on the Atom HE? I’ve searched the forum and the net, but I can’t find an answer.
You can do it from the settings, but otherwise details for a hard reset can be found on this thread here;
To factory-reset a Naim Atom HE (Atom Headline Edition) to restore default settings:
- Power on the Atom HE and let it finish booting.
- Hold down the front-panel Select knob (press in) and keep it held.
- While holding the knob, press and hold the top-right source button (the button labelled with the Naim icon / standby) — continue holding both.
- After ~10–15 seconds you should see the display change or the unit will restart; release both controls when that happens.
- Wait for the unit to finish rebooting — settings should be back to factory defaults.
Or using the remote go to home screen>settings>system and select factory reset.
Bruce
